120 thousand miles
120 thousand miles
Changed all fluids periodically, plugs etc. But my question is what should i be looking to do to make sure my car lasts another 120k? timing chain change? etc?
no major problems. I had the clutch recall done, the seatbelts, cv joints replaced (actually just swapped to stop the clicking) and thats it.
Should I be looking to do anthing else?
120,000 miles on the vehicle just proves to you the reliability of a Honda. You are the secrete to your own success! Continue the maintance on the vehicle that you have performed from the previous 120k. Also, telephone a local dealer and ask what could be expected, ie: Belts, Hoses, etc. Good luck with your next 120k !
i have almost 80k miles on my '00
anyway, just follow what the helm manual says on page 3-9. change the spark plugs if you haven't, replace engine air filter, inspect drive belt, replace diff oil, inspect all brakes, check parking brake adjustment, replace cabin air filger, check tire inflation, inspect tie rod ends and boots, steering gearbox, and cv axle boots, inspect suspension components, inspect brake hose and lines, inspect all fluid levels and condition of fluid, inspect cooling hoses and connections, inspect exhaust system, inspect fuel line and connection, check lights and controls, inspect vehicle under body
