12,000 rpm
Old 09-12-2006, 08:17 AM
Jsmply's Avatar
Thats why he changed the retainers. It's been said that they are the weakpoint of our valvetrain. If something is going to snap, they go first.
Old 09-12-2006, 08:41 AM
smyroad's Avatar
I'm guessing that it is possible to slightly damage a value (there may be no such thing as a slight contact with a piston ). In other engines, I've seen broken valves without obvious damage to the retainers.
Old 09-12-2006, 08:45 AM
djpeak10's Avatar
remember my car has ran great for 2 months, I think if there was valve damage I would know dont you?
Old 09-12-2006, 08:47 AM
djpeak10's Avatar
I was under the impression that with a zero tolerence motor like ours (11.1 compression) any valve damage would be noticed, again I am not sure though
Old 09-12-2006, 08:53 AM
Jsmply's Avatar
I believe you are right. If you caught it before the retainers cracked and dropped a valve, you did good!
smyroad's Avatar
If it's good after a couple of months you're probably fine. A good spark plug check would confirm it.
Old 09-12-2006, 09:10 AM
djpeak10's Avatar
that is what I was going to do next, if all the spark plugs are clean of oil what does that actually mean?
Old 09-12-2006, 09:18 AM
smyroad's Avatar
If all the plugs look about the same, then there's no valve damage.
A long time ago, there was a spark plug faq/post becauue some owners discovered one cyl was runing rich. It had some good pictures. Let me see if I can find it.
I couldn't find what I was looking for, but here are some other threads with pictures
From this thread
https://www.s2ki.com/forums/index.ph...pic=120093&hl=
there is a link to a page showing plug conditions and associated indications.
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
Another link from this thread
https://www.s2ki.com/forums/index.ph...pic=175564&hl=
shows damaged plugs also and points out that you should look at the porcelain when
s2pat
06-20-2012 04:03 PM
R.O.C.
04-09-2010 06:54 AM
R.O.C.
04-08-2010 09:10 PM
thatsahonda
01-04-2008 04:24 AM
114_ap2
17
12-22-2007 05:30 PM
Quick Reply: 12,000 rpm
