100psi oil pressure gauge enough?
I'm about to drop money on gauges and got to wondering if 100psi is high enough. On my other car it would only see 100 if it was dead cold in winter and I reved it much over about 3.5k before it was fully up to temp. I've read that this engine has a much higher than normal oil pressure, but I've never read what normal operating range was from dead cold in winter to max temp on track in summer. What kind of pressures do you see?
The pressure relief valve opens up at somewhere around 95 psi, so 100 psi should be adequate.
I have one that shows a max oil pressure of 80 psi, and I wish it went higher - it spends a lot of time maxed out until the oil warms up. However it is adequate, since I was really concerned over having enough pressure on the low end, not how high it can go. And I wanted a digital gauge, not an analog one.
Science of Speed has a really nice dual gauge A-pillar cover that really looks nice. This is what I have and I get lots of compliments:
It has the same texture and appearance as the stock A-pillar cover and the fit is great. They're a sponsor:
http://www.scienceofspeed.com/products/int...000/pillar_pod/
Spoolin
05-16-2010 08:43 AM
Moddiction
02-16-2010 04:53 PM
