1 cause of misfire codes found
Had a S2k in and had misfire in #2 , #3 . Found valve keepers sinking into valve retainers causing incorrect valve lash. It didn't have alot of noise at top end but was some. Found it with a micrometer and measured valve high from bottom of head to top of retainer.But when cams where out was very visible. Just though I'd let you guys know about this since I see alot of us with misfire problems.
Originally Posted by Slows2k,Mar 15 2005, 09:38 PM
I've edited your title to be more descriptive.
You may want to add what DTC's where present, and under what conditions.
I thought I was being descriptive by saying misfire in #2 & #3 but the codes for misfire in those cylinders is P0302 & P0303 or code 72,73.
Also idle wasn't bad but under acceleration part throttle is when light would flash, meaning when light flashes this is a problem that could cause cat damage, then light would stay solid.
Phantom327
04-13-2017 11:11 AM
