'07 primary o2 sensor diagram?
okay, i know there are 2 heater wires so thats an easy one but Im not sure which is the ground and which is the sender? HELP!
Not sure if all years have the same color wires but let me know what you guru's know.
Thanks!
Thanks!
Okay someone here has to work for Honda or know someone who has access to schematics?
I called Honda and they say they are too 'busy' to talk to the techs. Okay.
Help!
Help!
okay finally someone at Honda called me back. If your looking at the connector from the front the top left wire (blue) is the sending wire (+) and the top right wire (white) is the ground (-) and the bottom left wire (black) is the (+) positive heater wire and the bottom right wire (black) is the (-) negative heater wire.
There was a service bulletin with faulty A/F sensors for the DBW cars. TSB #07-006.
Hope someone can use this info!
S2KEvolution
06-20-2004 03:46 PM
