06 voltage problem?
Old 06-01-2011, 03:22 PM
idea-catalyst's Avatar
As observed in an earlier post, if everything is flickering it could be the alternator (actually the voltage regulator built into the alternator) but if only the gauges are flickering, then it's a bad ground. Turn on your dome light - does it flicker just the same as the cluster?
Old 06-01-2011, 03:27 PM
JmanS2k's Avatar
No, the dome light doesn't flicker at all.
Old 06-01-2011, 03:34 PM
If the dome light doesn't flicker, it's not an alternator problem.
Old 06-14-2011, 09:58 PM
teeteeracer's Avatar
my gauge cluster flickers too and also the radio turns off and turns back on. what could it be? help!
Old 06-15-2011, 08:13 AM
Billman250's Avatar
Received 1,343 Likes on 814 Posts
Flickering dash is due to a bad rectifier inside the alternator. Car will charge as normal.
Dash is sensitive to this. not the dome light or any other light in the car. It's not a loose connection.
Change the rectifier and your dash will be fine.
Old 06-15-2011, 08:52 AM
thank you Bill! I was starting to freak out cuz it would flicker more frequently as I drive. does the rectifier also affect the radio?
Old 06-15-2011, 03:46 PM
Boofster's Avatar
Rectifier issue.
https://www.s2ki.com/s2000/topic/801...t__p__19093100
Old 06-16-2011, 03:13 PM
JmanS2k's Avatar
Originally Posted by Boofster
How much does one cost?
TWISMS2000
10-31-2016 12:29 PM
bluesaint
11-29-2010 12:13 PM
blks2k06
07-24-2009 06:00 PM
S2KCDN
04-07-2009 09:59 PM
rosscoe21
11-19-2008 04:48 PM
Quick Reply: 06 voltage problem?
