06 bog problem / Flashpro remedy / solutions?
Old 06-25-2015, 09:47 AM
  #31
shind3's Avatar
Originally Posted by alSpeed2k
Tried doing this earlier, it was a total failure. I wasn't anywhere close to 40% throttle. Lol! Did you do this stationary? At 10% throttle, what rpm are you at?
It doesn't have to be exactly 10% and 40%. Basically just enough throttle to maintain speed/RPM. Then quickly change to a higher angle that's not WOT. Do this in gear at speed. I did it in 5th at around 3000 RPM on flat ground. Don't stress over the exact values. Just go from low throttle to mid throttle.
Old 06-25-2015, 09:49 AM
  #32
King Tut's Avatar
I agree with Gernby from the datalogs I have taken and looked at on my car, but I can perform your 10% to 40% test if you would like.
Old 06-25-2015, 09:50 AM
  #33
shind3's Avatar
Thanks.
I just want to gather some data. From 10 years of tuning engines, I know that anything much leaner than 15.5 AFR reduces torque noticeably and can hurt throttle response. If it's really lean like 17+, it'll feel like hesitation.
Old 06-25-2015, 11:15 AM
  #34
alSpeed2k's Avatar
Sure, I'll try later today.
Old 06-26-2015, 08:15 PM
  #35
alSpeed2k's Avatar
Tried after work, too much traffic around though and didn't quite hit 40%.
Old 06-29-2015, 12:23 PM
  #36
shind3's Avatar
Can you upload the actual datalog? If it won't let you do it here, you can upload at the Hondata forum. http://www.hondata.com/forum/viewtop...17928&start=15
Or I can PM you my email address. Let me know.
Old 06-29-2015, 05:23 PM
  #37
alSpeed2k's Avatar
Sorry, I never saved it and deleted it from my flashpro already. :/ I'll try again later this week and post-up.
Old 06-30-2015, 05:39 AM
  #38
bendang2005's Avatar
I need to get on this. I'm having the same issue also. Will try to get the datalog tonight.
Old 06-30-2015, 07:12 AM
  #39
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Billman, this has nothing to do with a WOT run, but thanks for your input. I don't always feel a hesitation but I do always datalog a lean spike during the Accel Enrichment phase.
Anytime.
Keep in mind it did not give him any problems at WOT, only on the initial application of the throttle. Once the "burp" passed, car would accelerate normally.
Old 07-02-2015, 04:02 AM
  #40
buldozr's Avatar
My '07 has started to do the same here in the last few months, hesitation on tip in at low rpm. High Ambient temps(not soaked) and high humidity seems to exasperate it. Pulling away from a redlight is now requiring concentration. Throttle body is clean, map sensor clean... I need to start logging and quit brushing it under the rug.
Quick Reply: 06 bog problem / Flashpro remedy / solutions?
