06+ AP2: SRS Light still on after Reset
Sponsor
Hey guys,
Any guidance to my next course of action?
I just reset the SRS light using the paper clip method. After the two flashes, the light still comes on, which I guess indicates there's an actual issue.
The only thing that's been done is that the seats have been removed.
I've checked all the plugs under the seat of the driver and passenger side and tried resetting again with the same results.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
When you swap the driver seat out, you have to keep the oem sensor under the new seat, in relatively the same position. If you replaced your passenger seat then I don't know what you can do, the weight sensors are on the actual rail.
Sponsor
Neither were replaced. They were just taken out and put back in.
__________________
_________
_________
Hello,
A body shop has be dealing with the same situation. It has come down to replacing the whole SRS unit. By replacing the whole unit, a code came up that said the seat weight sensors needed to be calibrated. Long story short, the srs system is a pain in the butt. All the shop has been doing is chasing around the demon to rid the lights and stuff. We have even bought a new airbag and everything. I would take it to Honda and have them look at it. I know that sucks, but they can probably do everything right. You probably need the seat sensors calibrated for the light to go away.
BTW, alot of stuff was taken so its replacing stuff to get everything working correctly. Good luck is all i have to say!!
LDubz735
02-05-2015 05:26 AM
