03' Grinds????
Old 11-10-2002, 11:10 AM
RevIllusions's Avatar
Default 03' Grinds????
any have a 2003 and found that the trans still grinds???
wondering if honda corrected for 2003...
thanks
Old 11-10-2002, 01:32 PM
JL9000's Avatar
I had 2 gear grinds, both happened in cold mornings.
Old 11-10-2002, 03:18 PM
FormerH22a4's Avatar
JL9000. Give this a try.
I let it warm up for about 3 minutes in neutral with the clutch up. Then I drive a block in 1st then shift. When you shift to 2nd for the first time, rev her up to 3500- 4000, fully depress cluth, then start the 1-2 shift.
If it blocks you, gradually add pressure. If it wouldn't go in, don't force it, just double clutch and then put it in. Your tranny will get bette as it wears in.
Old 11-10-2002, 03:27 PM
peterpan's Avatar
Nope. 22000miles and never grinded.
Never had mechanical problems PERIOD
Old 11-10-2002, 07:04 PM
JL9000's Avatar
[QUOTE]Originally posted by FormerH22a4
[B]JL9000. Give this a try.
Old 11-11-2002, 09:31 AM
Banned
wantgoback's Avatar
Old 11-11-2002, 10:01 AM
MondoRides's Avatar
Just put 1000 miles on my '03 and have not experienced any grinding whatsoever.
Old 11-11-2002, 11:17 AM
Former Sponsor
Gernby's Avatar
He is asking about '03s. You've got an '02, right?
Old 11-11-2002, 11:37 AM
Banned
wantgoback's Avatar
[QUOTE]Originally posted by gernby
[B]
Old 11-11-2002, 11:45 AM
Carlson's Avatar
Thanks! but as I said this has only happened twice, and when it happened, my engine was at 4k RPM with clutch fully depressed. Now when I'm warming up, I row through the gears before I leave the garage, that seemed to make shifting a lot easier.
What you experieneced was not grinding. The 1st-2nd gear grind is a nasty metal crushing action, you can hear and feel it, and you would not be able to put it in 2nd, you would have to go back to neutral and shift to 2nd again.
Quick Reply: 03' Grinds????
