02 sensor
02 sensor
im trying to change my exhaust. i've broke lose the first o2 sensor in the header no problem ( as i had to change header) and i got it back in. but the 2nd o2 sensor on the exhaust part wont budge for anything. my 24mm wrench slips. so i got vise grips on it as hard as i can and it still wont budge.
anyone think they can help?
you were lucky on the first sensor, it is 22mm, I just pulled both of mine. An o2 sensor socket works well too, you can actually torque it to spec with an o2 sensor socket, otherwise a 22mm open end wrench will do it.
Originally Posted by xasrielx,Feb 2 2010, 06:47 PM
ok well i dont have a 22 mm -.- lol sucks
ima just blast it with wd40 and use vise grips.
and then when i get the money i'll go buy a 22mm
those sensor are well over a hundred a pop adn they are very very fragile.
please save those new york wrench for home improvement project and get rent an o2 sensor adopter at autozone, did i mention it's free rental?
i didnt litterally mean soak it. i just applied it to the rusted bolt part a little around in a circle.
and i tried autozone and they didnt have any at mine ( our autozone sucks)
btw the wd40 and vise grips did the trick on the first try
