'00 vs '02 dyno HP differences
#31
Originally posted by ultimate lurker
The 2002 ECU is $555 wholesale.
http://www.hondaautomotiveparts.com/auto/j...NIT+%28CABIN%29
#32
Originally posted by schwett
i'm not sure this would necessarily yield the most accurate results. if you didn't reset the first computer before testing, it would have a different long term trim value than the second computer. if you reset the first computer, they'd both be zero'd out but not necessarily indicative of what trim the computer would arrive at after just a few days of driving. it would probably be better to reset your ecu, drive for a week, get on the dyno, swap ECUs, drive for another week, and get on the same dyno again in the same weather, preferably.
the HP differences we're talking about here are so minimal that i think you'd need to be very careful about the test methodology.
#33
Originally posted by gernby
...I don't think the long and short term fuel trim has any effect on WOT.
so either honda changed it, and the trim is no longer applied at WOT, or perhaps your trim was essentially perfect and nothing was learned at all.
this is an excerpt from a pretty good series of training documents on honda pgm-fi systems :
[QUOTE]
Another concept that is related to OL/CL operation is the ability of the ECM to "learn" an engine's PW requirements. The ECM's ability to learn an individual engine's PW characteristics is called adaptive learning by Honda. The deviation of the injector PW from the factory default base PW is stored in the ECM. PW requirements are only learned while the Honda is operating in CL operation. The information is stored as the parameter long term fuel trim (LT FT).
LT FT is given as a number with 1 being no fuel trim. When the PW is wider than the factory default the number of 1 is increased by that percentage. When the PW is narrower than the factory default the number of 1 is reduced by that percentage. For example, a Honda whose PW was 10% wider than the factory default would have a LT FT of 1.1 and a Honda whose PW is 10% narrower than the factory default would be .9. Screen Capture 9-6 is showing a Honda with a LT FT of .97, which means the PW is running 3% leaner than the factory default.
#34
There was a bad batch of 2000 ECUs. Mine was replace with a 2002. There was a noticable difference at idle (smoother) and right before VTEC (less notchy engagement). Two others in the Bay Area had their's changed around the same time.
#35
Do you think it would be worth it to check and see if the transmission is causing the difference? My friend said if the tranny was different then it would show up during engine braking. So he suggested we get two s2000's (an '00 - '01 and an '02 - '03) and drive side by side at around 60mph in 3rd gear and both let off and see who pulls ahead. His theory is that if you're losing less in the drive train then the '02 s2000 should pull ahead of the older ones.
Anyone think it's worth a shot? If so I'll post this in the FL forum and see if anyone in my area wants to meet up.
#38
Take a look at the difference in timing between a 2000 and 2002 car on the dyno:
http://www.kpj.com/S2000/DataLog.xls
The 2000 is a turbo and had an AIT of 86. My car is a 2002 with a SC and had an AIT of 118. There are of course other factors that effect timing, but the difference was huge.
-YS
-YS
#39
[QUOTE]Originally posted by Yellow Streak
[B]Take a look at the difference in timing between a 2000 and 2002 car on the dyno:
#40
I would like to see this comparison made on 2 NA cars with reset ECUs.
-YS
