*HELP*Removing lower perch on stock shocks!*HELP*
I'm putting in my Konis and can't get the lower perch off the stock shocks. Just wondering if i should just hit them until they come off or if there is a better way to do it. Thanks
ok if by perch you mean where the spring restes on the shock then why are you taking them off? I just did my springs replacing stock with Teins and didn't have to remove that? Please clearify and I'll see if I can help
Yeah...I'm retarded...I was think just spring replacement..uhhh
Anyway, I would guess that they knock off and that you have to tap from the bottom toward the shaft, looks like a taper fit.
PLYRS 3
03-01-2008 12:08 PM
