***Help! TDC P1362 code...***
#21
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
ok guys so i replaced the cps and still car wont rev more than 3k.. i also replaced the alternator and battery (thought maybe not enough power) but same... I just took off the ECU and I took it to get it check.. anything else you guys think I should check??
#22
#23
disconnect the negative and positive battery terminals.
touch them together, have a beer and then put them back on.
i had a similar problem on a previous car once and this solved it, computer had a brain fart i guess.
then again you just rebuilt the motor, could be mechanical.
#25
You haven't swapped the cam shafts have you? If you had swapped from a MY06+ they have different plates at the end of the cam shaft on the exhaust side. I had this issue when I was rebuilding my head and used the cam shafts from a MY05 on a MY06 w/ the MY06 sensor.
#26
Originally Posted by JesusGLS,Jun 17 2010, 12:15 PM
Ok..I'll have the ecu reset.....also if chain where to b magnetized how would I b able to fix dat? Do I have to buy a new timming chain?
#27
ok.....i havent replaced the cams but I think the previous owner did...how do I know if he replaced them and what serial # are mine suppose to have???
#29
Originally Posted by Stratocaster,Jun 22 2010, 10:28 AM
The chain being or not being magnetized would have no no impact.
I think your problem is the crank sensor and/or wiring.
#30
well to b honest dont know if it would have an effect but to get anything magnatized take more than just putting the chain or watever next to a mganet...
also... i already replaced the crank sensor ...
Ok so this is what ive done so far and what i have replaced...
I replaced the crank sensor, alternator, battery, camshaft position sensors, and ecu..
Now when i had my original ecu code p1362 would come out. I would change the wires around and car would not turn on. I would then put everything back again and change the sensors and same p1362 code came out...
I then replaced the ECU and reprogramed my key to work with my ecu and well now the p1367 code would come out. I also did the same thing.. changed plugs nothing, then changed sensors and same code came out.. now the funny thing is that when sensor TDC 2 is connected the car will not turn on... but once i unplug it the car turn on but of course car will not pass 3k rpm and now it idles rough..
Im really out of ideas and dont know what else it could b...any other suggestions of what it can b?
Im kind of getting alittle tired of this and well wouldnt really like to get rid of the car but... i would really appreciate if you guys could help me out. THANKS!!!
