***Help! TDC P1362 code...***
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
![Thumbs up](https://www.s2ki.com/forums/images/icons/icon14.gif)
Ok guys... so my car got a new code. The TDC P1362 code came out. I turn my car on but it doesn't rev more than 3k rpms. I checked and well this code comes out. Where is this sensor located or wat can i do to fix this problem? Has anyone experience this problem before? I would really appreciate if someone could help me out. THANKS!!!
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
There are 2 sensors on the valve cover. There are near the back. One on back drivers side and other on top pass side. make sure bolts are tight
# 8's
# 8's
![](http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/14s2a01_e09.png)
ok and how do i know wich one is bad? i checked some other member that had the same issue and well he replaced them and same thing kept happening...
Honestly, I do not know. Try swapping them and see if you get the same code. If so then I think the ring teeth thingies on the cams may have something wrong with them. But first I would check if one of the bolts rattled loose.
thanks ill have that check then.. also have you ever had anything like this happen to you or know anyone that went through this? if so, how did you solve it? ive seen 3 threads on the same thing but none have to get a solution...
Unfortunately no, not yet. My car is a weekend car and mostly a garage queen so I couldn't be of much help.
It could be one of those simple tighten bolt things so most people don't post back up.
a magnatized timing chain can cause an issue like this, but that would be hard to happen especially if the cars motor has not been taken apart or anyything. Maybe replace those 2 sensors on the valve cover. Did you over rev or anything like that ?
