Are your tires inflated at 32 PSI?
Well are they? I have a 2004 S2000 with stock tires and wanted to know if you inflate your tires to 32 PSI. Thanks
When I got it home from the dealer, they were at 40+ all around.
I run 'em at 33 now, and my butt can feel the difference on rough roads.
The max for the RE050 (stock 04 tire) is 51.
http://www.tirerack.com/tires/Spec.jsp?mak...l=Potenza+RE050
-geekd
-geekd
Originally posted by SilverKnight
The manual says 32PSI so mine are always inflated to 32PSI then I let them go to about 26-28 or so before they get inflated again.
ps. Mine's an '00 and I run 35. On an '04 however, due to the aspect ratio of the tires, you'd have to run factory specs till you figure out your tire wear pattern and then go from there.
-geekd
-geekd
