Work Meister 2pc
Work Meister 2pc
hey guys. hows it going?
I'm looking at getting some Work Meister 2pc rims (I think they look a lot better than the 3 pc) and was curious if anyone had them or just happen to know what offset is need for them to fit. i want 17x8... unless a 9 will fit without pulling the fender. i don't mind rolling but pulling is tricky.
thanks for your help.
http://www.workwheelsusa.com/product...ry=29&wheel=84
offset matters more than width
you can get 9" in the back with +40 and only need a minor roll
if you want to keep the body panels stock, go with a +55 to +65
the lower the offset, the nicer the rim will look
this will be moved to the wheels section
Anyone know where i can pick up a set of these in white 17x8 +35 (think that will fit all around) The only place I found is $760ish a wheel. Hoping someone knew a place where maybe I could get them a little cheaper.
thanks.
thanks.
