Why is coefficient drag bad in S2000?
#41
Originally Posted by S2-3456789-K,Nov 26 2007, 03:35 PM
question for the aero guys (or girls)...is Cd usually a calculated or measured value? i can see how it can be either, but i wonder which one is usually presented. for example, with top speed and estimated top speed claimed by manufacturers, there could be some discrepancy.
However, it can also be measured in model tests. And it can be calculated analytically.
It all depends on what problem you are trying to solve.
For cars the answer might be different. It's easier to measure actual cars in full-scale windtunnels.
#43
Originally Posted by mikegarrison,Nov 26 2007, 09:10 PM
For airplanes, it's generally calculated. What's measured is fuel consumption. Then thrust is calculated based on engine performance. Then CD is calculated from the thrust.
One method used with automobiles simply lumps all the sources of drag togehter. We take the car up to speed, and then measure the coast down rate. I now use accelerometers or GPS logging to get several samples per second, but we use to make the measurements with a stop watch at much lower resolutions. Once you have measured the coast down rate you can make changes to the car, and the change in the coast down rate tells you how effective the changes were. Works for aero changes, tire changes, etc. I guess it's a pretty crude approach, but it works quite well.
#46
For the physics guys, a question:
The pricinple that explains how airplane wings generate lift is well known, however, why is it that airplanes are able to fly up-side down when that is actually a contradiction to the same principle?
I never understood this.
#47
what matters is the angle the wing is presented to the medium.. called the angle of attack. a plane can fly and even climb upside down..just not as efficiently as it would normal-side-up
#49
