Where to find the template for the OEM rear wing
I believe the template for the rear lip spoiler and the rear wing are the same
I called all my local Honda dealerships and no one has the template
This should help you hopefully install that spoiler, good luck!
http://www.handa-accessories.com/S2000/s2kspoiler.pdf
The two outboard holes for the lip spoiler are marked on the underside of the trunk, just drill them out, if the wing uses the same holes then they are easy to find.
I bought a used lip spoiler and got the holes marked using some sticky band-aid thingys for the two inside holes as I did not get a template. If you are after help with the lip holes shoot me a pm and I can give you information on how I got the holes drilled on my trunk. If you are after the rear wing instructions I am not that familiar with it.
What I'm referring to is this piece of paper, the template:
Moddiction
03-16-2008 08:52 PM
