When does everyone's clutch go out normally?
Administrator
The idea that it only slips in vtec is odd. This may not be a worn clutch but something else. When you take it in make sure you tell them it happens in vtec. The clutch has 3 main components: disk, pressure plate, release bearing. You can screw up the disk by glazing it (overheating) by slipping it. If there is a problem with the release bearing it might not be disengaging fully and causing it to ride on the flywheel without you realizing it. If it's the pressure plate then it might have a problem where it doesn't apply enough pressure causing it to slip.
A slipping clutch usually causes burning which stinks real bad. Any smell?
Yeah I dont know, its weird cuz its only in vtec, and no I dont have any smell. That was the first thing I did when I got out of the car was try to see if I could smell the clutch.
Sick S2K,
You're not alone, I got the same problem. Only when I VTEC it starts to slip no fishy smell. Although I do remember once it did smell fishy after VTEC then it went away. But maybe the damage was done then and slowly got worse.
BTW I got 25,000 miles on the original stock pressure plate/disc.
Mike
Mike
Originally Posted by Brennon,Jun 6 2005, 02:31 AM
I have almost 42k miles on my 01. Open her up regularly, but I never launch....the original clutch is still going strong.
Ok quick question what would be a good aftermarket clutch to go with for daily driving, only mods are exhaust and intake. And where would be a good place to buy from. Thanks in advance.
Well, here's the latest on my clutch issue. I took the car down to Honda and went to have them look at it. They said I would have to pay for the diagnosis (even though it is under warranty). I already took a day off work to get the car in so I was not going to pay out of my pocket for this!
I talked to HardtopGuy (Excellent customer service BTW) and ordered a clutch from. He was suprised to hear how many miles were on my S, then informed me that my throw-out bearing might be the culprit. I then talked to a friend of mine who used to work for the Razarri dealerships and this is what he said:
The throw-out bearing going out could cause the clutch to stay engaged. He asked if I could shift without depressing the clutch pedal, and I can (dont even grind, it's almost like an auto!!). All I have to do is press the pedal in 1/4 of an inch for it to go into any gear, and with 2-4th, I dont even have to do that.
Since I've heard the throw-out bearing is like a defect from Honda, would they cover this under warranty? My car has 28K on it now....Anyone else have this issue before?
If that is the case, there is "no way in he**" that you should have to pay for the diagnostic!!!
I know that clutches are considered wear items, like brakes and windshield wipers, but is sounds like this place is just a little too eager to get you to eat a repair that Honda should be taking care of. JMO but I could be wrong.
Good luck and let us know how it turns out!
Steve R.
34k miles on my car, original clutch, and no signs of the clutch going any time soon. I autocross and do 6k clutch dumps every run, clutch is still holding up fine.
