Wheel Tracking Issue?
Is it common for an s2000 to track noticeably depending on the camber of a road? My S2000 constantly seems to track off to the left. I have had the tracking completed just at the front. Would it be worth getting a 4 wheel alignment, is there any other reason why this may happen?
verify the tires have functional wear and are inflated correct.
4wheel alignment; know the oem settings and go to a shop capable to do the work, give them the settings. the s2k is very dependant on how the alignment is setup. you should not have to do this that often and pick a shop that services the autox crowd. a shop may dial out the effect you are experiencing and cause a other bad.
