Wheel Alignment
I got some figures from the wheel alignment on my S2 - any comments would be appreciated:
Castor:
Left +6 Degrees 19 Min
Right +5 Degrees 35 Mins
Kingpin Inclination
Left +9 D 51 Mins
Right +9 D 42 Mins
Camber
Left -45 Mins
Right -21 Mins
Toe
Left -.6mm
Right -.6mm
Setback 10 Mins
The Toe from Specs should be 0mm.
I guess it is all a compromise of wear over handling, but it would be good to know what to advise the tyre shop
Castor:
Kingpin Inclination
Left +9 D 51 Mins
Right +9 D 42 Mins
Camber
Left -45 Mins
Right -21 Mins
Toe
Left -.6mm
Right -.6mm
Setback 10 Mins
Administrator
Here is what I have from memory. I really like this setup. Tirewear is quite even, feel is balanced and turn in sharp and quick. Please keep in mind I have lowered m=the car 1" or so with the Comptech springs.
Front:
Caster 6 deg
Camber -1.5 deg.
Toe 0 deg
Rear:
Camber -2 deg
Toe -0.5 deg
Again from memory.
Front:
Caster 6 deg
Camber -1.5 deg.
Toe 0 deg
Rear:
Camber -2 deg
Toe -0.5 deg
Again from memory.
hyperpm
08-31-2002 12:14 PM
