What the hell is wrong with my car now?
Old 02-13-2006, 09:49 AM
Jaydem's Avatar
Default What the hell is wrong with my car now?
at highway speeds..everything is fine until i accelerate and then let off the gas...car feels like it goes to one side for a second!!!!what gives??
any input on this? (P.S I also have the shaking problem in the rear..is there a connection?)
Jay
Old 02-13-2006, 09:50 AM
beanolo's Avatar
Did you check tire pressure?
Old 02-13-2006, 09:51 AM
beanolo's Avatar
Did you check tire tread? (sometimes tire pressures being off could lead to uneven tire wear which could cause that pull)
Old 02-13-2006, 09:52 AM
beanolo's Avatar
And what shaking are you referring to?
Old 02-13-2006, 09:59 AM
Cyclon36's Avatar
Yeah, first guess would be a tire that needs to be balanced and a tire pressure problem. S02's have a stiff sidewall so even at low pressure, they can appear to be full. I would check them all with a guage.
Old 02-13-2006, 10:09 AM
vtec9's Avatar
haha beanolo .. <--- Edit button
Anyway.. what they said. S2k is very sensitive to changes in tire pressure. If that doesn't fix it, could be uneven tire wear, or alignment problem.
Old 02-13-2006, 10:20 AM
Jaydem's Avatar
hopefully thats my answer...my rear es100's are kinda worn....
beanolo...My rear end shakes under acceleration due to axle wear... (car is lowered)
Jay
Old 02-13-2006, 11:26 AM
DrEvil's Avatar
I had the exact thing happening to me, checked pressure, and drivers rear was at 15psi.
Old 02-13-2006, 03:34 PM
Jaydem's Avatar
Thanks Guys
Old 02-13-2006, 03:50 PM
TunedS2000's Avatar
Jay
This is crazy... I had the same problem today. I am not sure what it is though. I know I need to get new rear tires (hell the tred is off to because my car is lowered). I'll check my tire presure and see if its that.
Quick Reply: What the hell is wrong with my car now?
