What are the factory alignment settings on a '00 S2000?
I'm getting new tires soon, and would like to have the factory alignement settings so that I can have a 4 wheel alignment done. So, does anyone have the factory alignment settings handy so that I can give them to the tire shop when they do the alignment? Thanks!
What Andrew said... but here it is again in a different format:
Factory spec
Front
Camber -0.5d +/- 0.17d
Caster +6.0d +/- 0.25d
Total Toe In 0+/- 2mm
Rear
Camber -1.5d +/- 0.17d
Total Toe In 6mm
And here's a more performance oriented alignment spec:
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6
Factory spec
Front
Rear
Total Toe In 6mm
Front
Caster Left 6
Does anyone have their car lowered and still use the factory alignment specs? I have I think a little over -2 camber and want to decrease it a little to avoid so much uneven tire ware. I have my car lowered about 2 inches with kg/mm race and Koni shocks set to the 2nd perch.
