Weird smell going up a hill.
I backed out of a driveway yesterday that is on a hill. I was facing up the hill and I started reving the engine (5000 rpms) to maybe peal out a little (just for grins). The car was still at 3 bars from earlier. So I was reving the engine with the clutch in and I let out the clutch and nothing happened is just kinda stayed there. Just enough to keep me from rolling down the hill. So I put the clutch in and let off the gas. I then slowly pulled to the side of the road. I noticed this weird smell sort of like buring oil (very noticeable) or something that screamed not good. Anyway I sat there for a minute and then drove to a gas station to look over my engine and oil level. everything was fine. MY car has 5000 miles on it. Any ideas. I was honestly freaked out all day after that.
Yeah, the engine spun and the clutch slipped freely. If you don't let the clutch out really quickly, for example side step it, it will slip helplessly. I tried that once with the same results. The guys that get good quarter mile times rev near 8k and side step the clutch.
The good news is that it should not affect the clutch. I've got 26,000 miles now with no clutch problems. Just don't do it again.
So I was revving the engine with the clutch in and I let out the clutch and nothing happened is just kind of stayed there. Just enough to keep me from rolling down the hill.
Damn the same thing happen to me. I pulled up at a light and this old guy, atleast 50 years or so, rolls down his window and asks if I can smoke the tires on it. I looked at him and said for sure. He replied, a kid like you probably doesn't even know how to smoke the tires on a sports car like that, come on I wanna see it, but wait till the damn light turns green he tells me. So, I get the RPM's up to about 8 grand and the the light turns green and I fether the clutch out out a bit and then dump it. Same damn thing happen, the car just rolled helplessly as the smell of burning clutch emiited from the car. I was so freaked out! beause I went through the light and a little father before letting up on the gas. At the next light I had to make a Right turn and decided to dump it. Wow....NICE,,,really fish tailing around the turn.
The smell was terrable though. I got back to work and the car sat for about three hours, then whenI got back into it, the smell was still there. Hoepfully it will go away.
1) You don't feather-then-dump, 'cause then all you'll get is clutch spin. The reason you dump the clutch in one very quick motion is to prevent the setup of clutch spin. If the clutch is out, the engine is turning, but the wheels aren't -- you're roasting the clutch.
2) This car really isn't good at "smoking the tires." It doesn't have a whole lot of torque at low-end, and it has grippy tires. I'd advise limiting the practice, because it will destroy your clutch and differential.
- Warren
- Warren
Every hear the expression. "Burning out your clutch" Now you know what they are talking about. It's a smell you don't forget. It reminds you to be carefull in the future.
