Weird rearview mirror question
Old 08-22-2010, 08:27 PM
s2k dre's Avatar
Originally Posted by davidc1,Aug 23 2010, 12:02 AM
OK. Normally when you adjust your rear view mirror you use your right hand and grab the right side of the mirror (unless you're in Japan, England or Austrailia). I just noticed that I can't grab the mirror on the top of the right side of it cause my fingers won't fit between the top of the mirror and the dome light. I have to grab the mirror on the right side itself.
It's not that I care exactly wear I have to grab it, it's just that it seems that it's mounted a little higher than before. As you know, in the S2000, it's already hard to see out the back window all the way down the road (to watch for cops you know), so having it mounted higher makes it worse. I've gotta scrunch down more.
Problem is I can't really remember what it was like before!
The metal piece is already glued on there from whoever made the glass. I had 3 windshields put on and all the after market windshields are like that.
s2k dre's Avatar
My oem glass had alot more space between the roof.
Old 08-23-2010, 02:52 AM
davidc1's Avatar
Ok, so it is in a different spot. Hmm, can it be moved?
Old 08-23-2010, 04:54 AM
takeshi's Avatar
It's very difficult to move the metal piece that the mirror mounts to. It's also very easy to crack your windshield trying to remove it yourself.
Old 08-23-2010, 05:35 AM
Reckon's Avatar
Maybe your fingers got fatter?
Just kidding, mine is fine and I don't have that problem, OEM glass and mirror as well.
Old 08-23-2010, 09:25 AM
chuhsi's Avatar
my non-oem windshield mirror location also isn't the same as oem. oem was maybe 2-3mm lower
Old 08-24-2010, 10:29 AM
Slick Shoes's Avatar
I had my windshield replaced and noticed the same problem. Kind of annoying, but the guy that put it in said he can't move it.
davidc1
08-25-2010 02:45 AM
Benihana
11-05-2009 07:27 PM
ryanfeldman
09-02-2009 08:08 AM
Elistan
11-15-2006 02:34 PM
Quick Reply: Weird rearview mirror question
