Weird Noise! Is This Really Bad?
So my new S2000 has started to make so funny noise from the clutch... during regular driving you dont notcie it cuz its not at a high rpm but when i drive it a bit harder when ever i let off the gas and just let the car slow down the stick shift and clutch pedal vibrate and the clutch makes a kind of a buzzing and woooing noise until i press the gas or push in the clutch... SO what does this mean? is the car going to need a new clutch or does it have a aftermarket clutch or is it just a defective thing that i am going to have to live with?
what year is your car. If I understand correctly there is a tsb for a clutch buzz on ap1's, you may be having that problem. I am sure somone else will chime in and give you more help, but i would take it to honda and let them check it out and then if it is the tsb you can get it fixed, and if not hopefully they can fix it for you.
