Weighted shift knob and cold 2nd gear shifts
Originally Posted by SIchodelic,Jan 23 2011, 03:41 PM
is it bad for the transmission to shift it into 2nd when it's cold and notchy?
If you double clutch, it'll go into 2nd gear smoother, but it's such a hassle
Heavy countersunk knob is the best, 250g for stock height is perfect, the lower you go the more weight u need to make it not too notchy. 450g at stock height is too heavy to me and made the shifting too soft.
GM fluid helps alot especially in cold morning. Regrease the shifter helps but not much.
On cool days I start off slower, shift around 4K and take my time the first 10-15 minutes of driving.
These days I'm more of the opinion that the Aisin transmission is good for about 30k mi and after that, notchiness is just a characteristic of its break in. A weighted knob will help with inertia in the shifts, but the transmission is just notchy.
Originally Posted by gtg749m,Jan 25 2011, 09:46 AM
Anyone else find that it also shifts smoother the higher you are in the rpm?
