Weighted shift knob and cold 2nd gear shifts
My 1-2 shift in cold weather is a bit notchy--after some searching around here it's apparently not all that uncommon. After the car's been driven for a bit the notchy feeling goes away.
I've got a lighter-than-stock countersunk shift knob right now and I think it might be time to invest in one of the heavier knobs. I've heard this helps the notchy feelings go away or become less noticeable. Is it worth buying a heavier knob just for this (even though I've already got a countersunk knob)?
I did these three things that helped the notchiness go away:
1. Change transmission fluid to GM Synchromesh Friction Modified
2. Replace clutch master cylinder and slave cylinder
3. Regrease shifter bushing
Anything else is a band-aid
Former Sponsor
With any weighted shift knob it will numb/remove the notchy feeling felt with a aluminum or light weight shift knob for sure. So it should feel better, but not totally remove the cold 2nd gear shifts
Originally Posted by zzziippyyy,Jan 23 2011, 10:53 AM
new Honda fluid > Gm syncromesh
I got a skunk2 one btw. I forget how much it weighs exactly.
Originally Posted by Sfedai0,Jan 23 2011, 01:17 PM
The notchiness is really only there at the very start....as soon as the car warms up the shifts should be smooth.
Former Sponsor
It won't fix it as others have said but does make it feel much smoother than with a lightweight shift knob. I have a slight notchiness going into 2nd and 3rd I think but once it warms up mostly goes away.
I could never go back to a lightweight shift knob though.
