Washer fluid, how far up when filling?
How far up can you fill the washer fluid in the 06's? I cannot get it to fill all the way up to the cap - does this mean the bottle broken? If I add more, the fluid hits the ground?
If it is broken, how can I access this area? Is fender removal a must?
I cannot get it to fill even to a place where I can look in it and see it.
Any input? Would this be covered under warranty?
The unit is comprised of two pieces: the reservoir itself and the filler neck. If you can't fill it all the way to the top there is probably a leak at the joint where the filler neck fits into the the reservoir. It's just a press fit [I think it's a O-Ring].
You have to pull away the inner fender to get at the reservoir.
