VAFC install diagram
Here you go:
https://www.s2ki.com/forums/index.php?showt...0&#entry6829413
Just ignore the components you're not using. If you need a hand feel free to PM me (or call I'm on the FL contact list). I've also got the Helm's manual w/ the ECU pinouts if that helps.
Honestly though, it is worth it to get a wiring harness and do the solders outside of the car. Much easier that way.
Mmm, no there are a couple of differences. I don't remember off the top of my head what they are. Do you have the vafc wiring info? b/c i can post or pm you the ecu pinouts.
That's certainly the easiest (and cleanest way). With the harness i have (which was a vafc1 harness i had to modify btw) I still had to solder in the vafc wires, but the harness was clearly labelled and it was pretty easy to do.
