V8 Powered S2000
#221
Wow this is incredible! Top notch modification as well.
I don't understand why people are hating on this so much - it's a cool project and he has to do a LOT of just-in-time engineering to pull this off.
I can't wait to see this finished! It looks like Xyster is doing this a lot more professionally than the other "LS2000" in the video.
I'm curious what you're doing with the wheels, also. The AP1 wheels on the other LS2000 looked like dredels on a power drill. I see you've swapped out the Honda wheel mounts and lugs as well as put some seriously wide tires on.... what kind of wheels?
#222
nice build. don't mind the haters here and there. just like people will say that a 4 banger that makes less than 200 lbs/ft of torque is no sports car, people will say this is ruining the s.
i think that if our cars came stock with this set up no one would wine, i mean how much more does the new engine weigh ~100lb? who cares, with all the other stuff stripped it would make little difference.
i mean were we all not begging for a car the weighed about 2500 lbs, that had 300-350hp? well here is an example of someone making one... though this will likely have a bit more power!!!
i cannot wait untill we have a track vid of this thing. with the right set up it should put down vett like numbers if not better.
#223
I was reading this hoping for a cheaper solution to the 300zx rear end swap, doesn't seem like any rear end for us is ch3ap. Congrats on the build, that shaved engine bay is looking mighty fine.
#225
no it will be painted when the car gets painted, after it has gone through its tests and make sure everything is good before I would have to repaint something because I had to change something.
#227
Hey Id love to check this out when you get it together next time I went to LA, we should swap cars for a bit!
#228
Well I got the clutch bled and made a custom shifter for it today and pushed it out of the garage and fired her back up adjusted the fuel pressure and she ran so nice and then I DROVE her back into the garage HELLZ YEAHZ!!!!!!!!!!!
