trouble shifting well
I'm a relative newb when it comes to driving a stick. This is my first manual car that I have ever owned; before this I only drove friend's manuals. So, I need some tips to get from first to second cleanly and fast. If I shift too fast the engine is too hot and shifts funny. If I shift too slowly the engine has to catch back up. Either causes a lot of bouncing. What is the best way to make it work well? I've resorted to letting the clutch out slower to help compensate for my poor shifting, but I don't like this as a long term solution. Any ideas? Thanks in advance.
BTW, I have an MY02 Silverstone/Black.
Cheers
Cheers
Looks liek you have an MY00... Hmmm, nonetheless try pulling it back while guiding alon the outer gate to the left- not too much pressure just guiding... Also it helps to cup the shiftknob with your hand over it (like a punch) rather than holding it like a gun (picture sawing).
Good luck and be easy on your syncros!
Try changing your tranny fluid to something like Redline MTL or GM Synchromesh. If you have the OEM Honda MTF (Manual Transmission Fluid), you may find the synthetics offer a smoother shift.
Word to the wise though........this car is notorious for notchy 2nd gears, so don't be too hard on yourself.
-Hockey
-Hockey
I think there is nothing wrong with the car. this guy just doesn't know how to shift properly. What it sounds like is you are not matching revs for the next (2nd) gear. What you should do for a while is to always shift from 1st -> 2nd at the same RPM....say in 1st gear you always shift at 4K for example. Then figure out at what RPM it is in 2nd gear at this same speed......say 2500 RPM for example. Then always shift when you're at 4000 RPM and let the clutch out when you are at 2500 RPM (actually slightly above this RPM because you need some time while you're letting out the clutch for the revs to drop). Then do this for every gear until you get more familiar with the car and know at what RPM you need to be in each gear for a given speed.....
Originally Posted by R11,Nov 5 2004, 11:20 AM
This is 2004. A good tranny with decent syncros should not require any "finesse". Sounds like he just needs to keep practicing to me.
ron
ron
I'm sure that practice will help because there are times when I get it just right. Unfortunately since this is my play car, I don't drive it as often as I would like. I notice that I'm just not very good at matching the revs. Maybe I should just slow down and drive it easy until I'm better at it. It is easy to shift at very low RPM's, but it is progressively more difficult as I rev up the engine in a particular gear. I've only put 1k miles on it in 5 months so I don't get into it that often. Thanks for the tips.
Cheers
Cheers
Cheers
Cheers
