trouble in the rain?
Old 04-07-2014, 01:01 PM
  #21
cosmomiller's Avatar
Received 1,753 Likes on 1,045 Posts
Originally Posted by SheDrivesIt
There are no tires called "Drizzles". I suspect you have Dunlop Direzzas. There are several Direzza products, I suspect if you had the more appropriate tire for the S (The ZII)you would probably be pretty pleased with the wet performance as these extreme performance tires have very solid hydroplane and wet traction performance scores. I suspect you have the lower level DZ102 or more likely the older DZ101 which have significantly lower wet performance scores.
You are absolutely correct. I used the term "Drizzles" as I heard other S owners who seemed to be pretty knowledgeable about tires, use it. I just coped them.
The tires that are about to be replaced (with summer Pilots) are indeed the DZ101. It what the previous owner installed. I have put 11K miles on it since. Fronts will last a little more. $495 out the door at California Costco. ($212/tire)
In dry, warm weather I thought the Dunlops handled pretty well, but I don't have too much to compare it to.
Old 04-08-2014, 05:51 AM
  #22
dakao's Avatar
All the RWD cars very easily to skid during turn on wet road..
No matter what tires you have and if you step on the gas while turning the car will skid..
Old 04-08-2014, 05:58 AM
  #23
Car Analogy's Avatar
Received 1,471 Likes on 1,086 Posts
Um, so will equally powerful fwd cars with similar tires in similar conditions. The difference is a rwd will tend to oversteer when it skids such, while a fwd will understeer. But they can both 'skid'.
Old 04-08-2014, 08:20 AM
  #24
kolyan2k's Avatar
Mostly its tires, VSA does wonders too. I drive 80mph if its sunny or heavy raining and never skidded
Jony0110
09-12-2011 06:31 PM
LubedKoala
08-19-2008 02:47 PM
edhs2k
07-22-2008 11:23 AM
killabee
02-23-2008 06:51 PM
knlg
10-12-2005 01:12 PM
Quick Reply: trouble in the rain?
