Transmission may have blown
Old 06-19-2022 | 12:31 PM
turbojonn's Avatar
Default Transmission may have blown
The Dyno guy was hard launching my car trying to set the 2 step and something broke. From the sound of it I thought it was the diff. I just pulled the axles and driveshaft and the diff turns smooth as silk both from the axle sides and the driveshaft side, and it’s smooth rotating forward or backwards.
When I was waiting to have the car towed from the Dyno place I did let the clutch out and it made a crunching spinning sound. I’m guessing that the tranny blew. Hers the thing I can’t figure out:
With the car on the jackstands and the driveshaft off I ran the car and put it through all the gears. There’s no crunching noise and I can see the front half of the driveshaft rotating when I let out the clutch?
Thoughts?
Old 06-21-2022 | 05:34 PM
umair's Avatar
Did you try to drive the car in 2nd gear instead of 1st? I think if he damaged something its gonna be a gear. It should move in one of the gears when on the floor. Otherwise it sounds like a clutch issue?
Old 06-21-2022 | 08:39 PM
turbojonn's Avatar
Thanks for the reply. I was so convinced it was the differential i pulled apart before I realized the differential might just be fine. In the next couple days I’ll put the axles and driveshaft back in and do what you are recommending.
Thanks again for the reply, Jonn
Old 09-05-2022 | 11:43 AM
turbojonn's Avatar
For those who search this topic in the future I wanted to follow up.
NOT the tranny, not the diff, not the clutch.
It was this:
was the axle. if you put your car in gear and it grinds in every single gear the rest of the position of the wheels it will likely need the axle. You can see the axle hopping inside the boot if you have a friend look at it while it’s in gear, ebrake on and clutch disengaged.
The piece in the pictures is located within the inner axle bearing cup, and holds the three bearings inside the cup. The inside bearing clamps around the spline, so when it broke andpopped open end it meant no more moving car.
Old 09-05-2022 | 12:04 PM
cosmomiller's Avatar
This car is not a drag car and many stories of hard launches tell a tale of mechanical woe.
turbojonn
06-02-2022 06:04 AM
Hondaplease
06-06-2014 05:13 PM
p0staboy
02-24-2013 03:42 PM
dripking07
09-01-2010 07:02 AM
pli
07-27-2008 04:33 PM
Quick Reply: Transmission may have blown
