Transmission issues...
Ok, here's the deal:
MY00, 60k miles. The transmission is perfectly fine on upshifts and downshifts. However, if I'm stopped at all, and I happen to let the clutch out and shift to neutral, I'm screwed:
- clutch out
- clutch in
- try for 1st... won't let me into the gate
- same for just about every gear except 3rd, which I can finally slot into with some effort, at which point I can row through the entire gearbox perfectly normally.
- same scenario is repeated if I shift back to neutral and then clutch out
The problem lessens as the tranny warms up. The tranny oil was just changed (Honda MTF).
Any thoughts on a cause?
- clutch out
- clutch in
Well, that obviously occured to me as well, but it'll be a cold day in hell before my car goes to Honda for anything other than a total failure.
There's no evidence of anything wrong with the clutch, other than the decel noise. No slippage, etc.
Try changing the clutch fluid
I did that with mine when i had a problem shifting into 5th.
But i haven't gotten out to test it enough to see if it worked.
But the bottom of the reserivor was black.
I did indeed bleed the clutch as well. Clutch action feels better, but no change in the tranny.
I took the car for a ride tonight, and blasted along for a good dozen miles or more.
The tranny is completely fine once it's warmed up, it's just the cold apparently that's causing a problem.
Is Honda MTF really this bad for cold weather use???
I have the same prob with my '00 with 31k. When it's cold, can't get into 1st or rev while standing still unless I run it through 2nd or 3rd first. It is fine when completely warm.
I changed the trans fluid at 15k with Honda MTF and then again at 30K with Red Line and it got a little worse so I changed it back to Honda's.
Still have the prob, thinking it may be the clutch fluid, master or slave. I am very easy with clutch, often getting 100k out of a car. Hope it's not the synchros.
Let me know what you find as a solution.
