Tires for S2000
Old 06-04-2004 | 09:09 PM
Diablo Chimp's Avatar
Default Tires for S2000
My odometer just went over 15,000 miles, and I need new rear tires. The current tires are original tires. They are Bridgestone Potenza S-02. Should I buy another set of Potneza? Any recommendations on equivalents to Potenza tires? Thanks.
Old 06-05-2004 | 06:52 AM
S2k Dude's Avatar
Depends on how you drive the car, if aggressively then stick with the OEM S02's, if not then you've got lots of different ones to choose from. With 15,000 miles on your first set I think you fall more into the "not" category unless you do an extensive amount of highway driving as well.
In order of personal choice:
1) OEM Bridgeston S02's - Best dry grip, wear quickly, slightly expensive.
2) Kuhmo MX - Cheaper than the S02's and almost as good, slightly better wear.
3) Bridgestone S03's - good wet weather grip but similar wear as the S02.
Old 06-05-2004 | 08:36 AM
apex2k's Avatar
Take a quick read of this, it relates should you decide to go with something other than the S02s.
http://forums.s2ki.com/forums/showthread.p...&threadid=48572
ralper
11-30-2005 12:00 PM
S2000-
10-07-2004 02:04 PM
sms
10-20-2003 10:37 AM
WhiteS2k
10-31-2002 11:08 AM
Colin
08-16-2002 07:21 PM
