Tien RA suspension help please
I bought some used (already put together) Tein RA coilovers.
Like a dumbshit i started playing with them for the heighth, because when they were first put on the sides were not even (ie...both left and right fender heighth was not exact on each side).
Anyway.... the only way i could get the rear close on each side, i had to adjust the drivers side way down on the threads compared to the passenger side. is that normal?
Scot
Scot
one of the main advantages of height adjustable suspension is so that you can corner balance your car.
put them on and have you car corner balanced. Don't try to do it yourself at home (it's not easy).
adjust them all either all the way down or all the way up, then count your full turns , make a mark on the portion you are turning when that is facing you again then that is one full turn, hope it helps
turtlepower
11-27-2012 11:39 AM
