throttle body spacer? under drive pulleys? bigger throttle body?
Old 02-25-2004 | 10:22 PM
speeeding's Avatar
Originally posted by vvtli78k
spacer adomzies the charge improvesmid range and topend power,
This is only for much older cars w/ "throttle body injection" where the injectors were part of the tb.
Old 02-26-2004 | 04:17 AM
S2K4ever's Avatar
hi i was wondering if anybody makes a throttle body spacer? or even if someone makes under drive pulleys? or even a bigger throttle body? all the help would be appreciated
karan
Edelbrock makes a TB spacer and brake line kit for our car. http://www.edelbrock.com
Part # Description
38112 Victor Series Racing; Throttle Body Adapter; 70mm;
38122 Victor Series Racing; Throttle Body Adapter; 75mm;
Description: Brake Line Kit;
Part No: 684490
Old 02-26-2004 | 05:21 AM
KAMcDonald's Avatar
i think edelbrock spacer is more a function of making their TB fit correctly. i did not see where it said s2000 specifically, just Acura/Honda. not sure if any of us have gone and bought one of these, most people have the Spoon or Proflow TB.
Old 01-02-2007 | 06:24 AM
Dark's Avatar
Bringing out the dead.
Found this TB spacer link and thought I would toss it into the topic.
http://www.autopartswarehouse.com/performa...=2002&partid=22
Old 01-02-2007 | 07:32 AM
TB's Avatar
TB
Not to be a nay-sayer, but I dont see 8 hp, 10 ft-lbs, and 3mpg coming from that on our cars.
Cool find tho
Old 01-02-2007 | 10:06 AM
Red_Devil's Avatar
How it work
Old 01-02-2007 | 12:07 PM
wildcardtrd's Avatar
Unless your fuel is injected before the spacer, having more plenum space is only going to increase the lag in the velocity of the air charge when going from zero to WOT on the throttle.
If you want your air/fuel mixture to atomize better with the stock manifold, plug your injector ports and re-drill them further up the runners...of course, Honda would have done this for you if they thought it would help. Having the injectors as close to the valves as possible makes for the smoothest idle possible, something car manufacturers have much interest in. If you're really intent on picking up throttle response, get a set of individual throttle bodies. You can't top that for throttle response or air fuel atomization, period.
Old 01-02-2007 | 05:21 PM
Dark's Avatar
The reason why most say you need the injectors as close to the cylinders as possible is because if they are higher up the runners you risk fuel from one plug making it into the plenum and down a different runner screwing up the mixture.
I think the spacer is a joke btw, just thought I would share the link
theS2K
09-02-2013 02:57 PM
BirdsS2K
06-24-2009 06:20 AM
kutsujula
09-14-2008 07:57 AM
J_STATUS
06-09-2008 04:33 PM
forplay
02-21-2007 06:14 AM
Quick Reply: throttle body spacer? under drive pulleys? bigger throttle body?
