For those who change oil themselves
Originally Posted by xman,Oct 3 2004, 08:07 PM
Or can I use the standard tool every Jiffy Lube uses...??
Let me know.
Thanks
X
Let me know.
Thanks
X
For the oil Pan, a socket and a ratchet will do the trick. I can't remember the exact size (old age) but someone will tell you,
As for the filter, I recommend getting a new filter, and then going to PEP boys where they sell all the different filter tools that go right over the end of the filter. They cost about $4.00 and work great.
The metal strap style wrench can work, but you don't have much room to swing the handle.
Bill
Let me know.
Thanks
X
Let me know.
Thanks
X
i use the metal strap style wrench, works cool for me, i hand tighten it as tight as i can get the filter, then i give a little baby turn with the universal filter wrench for some torque i can't get with my weak small hands, plus i usually get oil on the filter, enough for my hands to slip so thats why i use the wrench.
I use an oil filter wrench similar to this one to remove the filter...
http://www.toolprice.com/product/7260B
The harder you pull on it, the tighter the claws grab the filter. Works great! To install the filter, I fill the filter with oil about 3/4 full (to prevent oil starvation on start up) , lube the gasket and just hand tighten.
LostWaffle
03-15-2004 06:54 PM
