Those with the Clutch Master Cylinder leak, call this number..........
Old 02-14-2004 | 06:10 AM
PanhandlingS2K's Avatar
to the NHTSA (National Highway Traffic Safety Admin.) and report it. If this fluid is leaking into the foot well it could very easily create a safety issue according to a friend who once worked at NHTSA. It would not be a safe thing for oil to be on the bottom of your shoes while trying to brake, accel. or even clutch. Also, some who aren't mechanically aware may not even notice this problem being that the fluid is black and the carpet is black. Call this number and report it if you have had this problem please!! 1-800-424-9393
P.S. If enough complaints are registered the NHTSA will force Honda to fix this problem.
Old 02-14-2004 | 06:29 AM
S2k Dude's Avatar
I have the problem but I'm as far as I've seen on this board it's not even close to being serious enough to warrant a call to NHTSA.
Seems like an isolated case that only a few of us have had.
Old 02-14-2004 | 09:04 AM
s2000guy's Avatar
First of all I can not imagine how the leak from the clutch master cylinder can leak enough to get on the pedal. This is impossible. If anything it may just damage your carpet.
Second of all why is it that when something on our cars breaks everyone wants Honda to fix it for free. FIX IT YOUR F***'N SELF!!!! Car parts are not build to last forever. They do break!!! That is why we have auto repair shops.
Old 02-14-2004 | 09:41 AM
Hustn's Avatar
It is entirely reasonable to expect the clutch master cylinder to last at least 5 years. The first two posters' cars are one and two years old.
I can't imagine this would not be a warranty item. Take it back to the dealer.
Old 02-14-2004 | 11:01 AM
Spankee's Avatar
Too bad this happens to all clutch master cylinders in all cars. Its a wear and tear item and isn't designed to last forever. When it does leak its just a very slow seep and will not get over the pedal itself but on the firewall and such. If you check your fluid often and notice it gets low its telling you to get it replaced or its your own fault if something happens. Just like when your brake pads hit the wear indicator and you ignore it and keep driving. You want Honda to fix that also?
Old 02-14-2004 | 11:37 AM
Silvers808's Avatar
mine clutch master is leaking, and i only have 18,500 miles on my car.....
hadeediqbal10
04-30-2013 10:37 PM
laserred02
11-28-2012 07:12 PM
Rosso_Corsa
10-07-2010 08:39 PM
refect
02-27-2010 06:39 PM
rudeboy
06-12-2006 07:17 AM
Quick Reply: Those with the Clutch Master Cylinder leak, call this number..........
