Is there a way to reset the SRS light?
If it's like the Prelude, which I believe it is, this what you need to do...
Make my own SCS service connector with a switch (basically a jumper cable with a switch to open and close the connection). This is what mine looks like...
- I located the MES connector (it's yellow plug under the dash) and plug in my SCS connector with the switch on the 'on' position.
- Turn the ignition switch to ON II.
- The SRS light stayed on for 6 six then shut off.
- I turned the switch to the 'off' position within 4 seconds of the SRS light turning off.
- The SRS will appear again and I turned the switch back to the 'on' position within 4 seconds of the switch turning back on again.
- The SRS light will turn off and I turned the switch to the off position again within 4 seconds of the SRS light turning off.
- The SRS indicator light will blink 2 times which means the memory has been erased.
- Turn the ignition to the OFF position and wait 10 seconds.
It worked for me on my Lude. FAQ this!
Keith
Keith
Could anyone please confirm that this procedure is identical/correct for the S2000? Also, will any low voltage switch work, or does it require something more specific? Thanks!
Originally Posted by 3ngin33r1,Oct 14 2003, 04:23 PM
thanks
If anybody knows how to reset the srs light, can they help me at the south florida meet in january. I tried reading the helms manual picture they have on how to do it on the site but the font is too small.
Thanks.
Thanks.
