Tein EDFC owners, question
I am asking this question for a friend of mine who has Tein's with the EDFC. He appearently read the directions and spoke to a few people and no one is sure if you can safely adjust the damper while moving. Anyone know?
I don't think it will break anything to adjust it while moving ... but turning on/off the EDFC unit to re-calibrate means your memory settings will be lost.
Now this topic is very interesting. I have this big ? regarding the adjustments. I have read many times that if you change the height of the car/suspension your car must be aligned.
The Tein is adjusted only in relation of how stiff you want the coilovers? or adjusts the height as well with the EDFC?
For cars with hydraulics where you can actually change the ride height of the car on the fly ... I would imagine you'd align your car to whatever setting you wanted first and then if you change the ride height your alignment would just be off until you went back to your 'correct' setting. Unless hydraulic systems also include the ability to change your camber/toe on the fly? I'm not really familiar with them at all.
Thanks LiQiCE,
Need more response. Seems that no one is sure if it will cause damage. I know there are a lot more EDFC owners here. There was just a group buy for them.
I have had mine for about a year, and I change it while moving. Not often, but I do it. I havent had any problems with my setup. I thinkyou should be fine, but whenever you can just do it when youre stopped to be on the safe side.
i change mine while moving a lot.... and i've been fine.. and i dont' have that problem that liqice has........ the only problem i've had with needing to recalibrate the edfc unit is when i put my cell in the cup holder... supposidly the frequency or something messes with the edfc and it thows an error signal...
however with all this said... tein does state not to adjust the dampening while driving...
I think changing damping rates on the move was the original Idea wasn't it? When your on the track you can adjust it on the fly until you get it right?
But someone should just email Tein and find out.
it was not intended for that. it was inteded to be able to adjust it on the go.... so instead of stopping and popping your hood and adjusting it and taking out the liner in the back to adjust the rears.. you just push a button....
if you read the edfc insturction booklet it'll say to NOT adjust it while the car is moving.. it must be stopped... just for safety measures....
however i've adjusted it plenty of times while i'm moving and there has been no ill effect
