Tear in Roof
Old 10-10-2024 | 03:05 PM
Soof's Avatar
Default Tear in Roof
A 3/4 in. tear just appeared on driver's side.
Any suggestions as to how to treat? Tape, super-glue???
Your help is greatly appreciated.
Russ
Old 10-11-2024 | 12:38 PM
Car Analogy's Avatar
Two steps, fix it, prevent reoccurrence.
Prevent reoccurrence = file down sharp edges in metal infrastructure. Coat w paint to prevent corrosion.
Fix = adhesive canvas patch. One inside, one outside
Old 10-11-2024 | 03:38 PM
Chuck S's Avatar
You can patch it and done well it will be almost unnoticeable. But you'll always know it's there shining like a giant wart screaming [exaggeration]"the owner doesn't care about this hooptie car!!" [/exaggeration] Start saving for a new Robbins cloth roof, you'll feel better.
-- Chuck
Old 10-12-2024 | 08:10 PM
darcyw's Avatar
Clean the area to be fixed and the soft top patch with rubbing alcohol. Cut the patch to size, giving yourself an extra 1" all around. Round any corners of the patch to prevent lifting. I use black silicone adhesive and press the patch into place, matching the fabric side to the fabric side on the inner side of the soft top.
This method has lasted me years. I haven't needed to patch the outside so I don't know how this method would work.
darcy
Old 10-13-2024 | 10:27 AM
cosmomiller's Avatar
You might try these Gear Aid patches. Pre cut, blends well and impervious to folding and water. I use them for permanent patches to backpacks and other equipment from abrasion and bear attacks. REI carries it.
Old 10-13-2024 | 01:24 PM
Chuck S's Avatar
The
Gore-Tex version Gore-Tex version
of the Gear Aid patches worked wonderfully both internally and externally on my '06. As noted earlier the patch was barely noticeable but it still bothered me enough to replace the roof a couple years later.
-- Chuck
cosmomiller (10-14-2024)
P.J.
07-17-2011 12:57 PM
LateBrake
08-25-2010 04:54 PM
javbrat
01-19-2010 11:06 AM
hoppingdeth
05-29-2008 06:04 AM
Quick Reply: Tear in Roof
