TB Bore done... I have a question
I just received my throttle body back from Proflow and I am curious about the "primer like" coating they used on the back of the butterfly and air flow path. Is this to make a complete seal when closed? It seems a little "cheap" and uneven.
Should I just leave it alone?
Shaner > Yes, that is what the gray coating is used for. If you remove this coating it will cause erratic low speed idling. It is impossible to get a 100% perfect seal and that is why Proflow used it. It does not hinder the performance.
beefystud
02-28-2018 04:47 PM
