tapping sound after 4500RPM
Old 04-02-2001 | 04:15 PM
Jon Corbett's Avatar
Does anyone else hear a tappy, papery sound after 4500 RPM's? If not, WHAT'S WRONG!
(P.S. This has been occuring for quite some time. Before I took my intake box cover off. doh!)
Old 04-02-2001 | 04:22 PM
Flayer's Avatar
I've got a tapping kind of sound that seems to come from
the dashboard somewhere. It is most obvious with top up,
while decelerating around the 4500rpm range. I'm taking
the car to the dealer tomorrow to try and have it
diagnosed. I'll let you know what I find out.
Old 04-02-2001 | 07:11 PM
Utah S2K's Avatar
Better Email Barry..........
Old 04-03-2001 | 05:20 PM
Flayer's Avatar
I got my car back from my dealer regarding a chattering/tapping type sound around 4500rpm. It
was diagnosed as a "normal" sound and dismissed
(based on a comparison with another S2k that
happened to be in the shop).
A description of the sound I had (hard to do, since
funny noises are so subjective) is basically a
higher-pitched metallic rattling/chatter/tapping
coming from the dash area (maybe more towards the
engine area though) that appeared around the 4000-4500rpm range. This appears most readily if you're in 3rd gear
(with the top up), take the rpm's up to 5000 and let your foot off the gas. The chattering will show up as it falls below 4500 till about 4000 rpm. This was noticable above
the standard engine noise.
I had checked the mirror and the visors, and they weren't
the cause of the problem. I believe it is a clutch/transmission chatter since it goes away if I
push in the clutch while it's chattering. Anyways, hope
this helps ID one of the possible random noises that might
pop up in your S2k.
Old 04-03-2001 | 05:33 PM
ITR's Avatar
ITR
I have the same metallic noise above 4000 rpm, seems to get worst the higher the RPM, I think it's normal for this car (at least I hope so)
Old 04-03-2001 | 05:52 PM
Rowland's Avatar
Gentlemen,
TAP, TAP, TAP is best to be left for the dealership. Not to say you have the #4 Cyl. problem, but that is one of the symptoms. Do a search on "Barry WY", he has compiled some very good information on #4 problem. It is best to have them check it out. I had my baby back in just over a week.
I hope that cars are OK and that is not the case. Good luck.
Old 04-04-2001 | 08:24 AM
I'm getting me second oil change in a week or two. I'll probably have them check it out then. Is it a bad idea to wait?
Old 04-04-2001 | 08:33 AM
OH yeah, another thing. I VTEC'd today, adn when I stopped, it idled horribly, like it was about to bog out. Not good.
Old 04-04-2001 | 08:38 AM
Rowland's Avatar
You probably should not wait if I were you. And do not VTEC before you some other damage.
Old 04-04-2001 | 08:42 AM
Yeah, that's what I was thinking.
Thanks for the help, I don't know where I'd be without this board. Honda should endorse it and tell all new owners to come here
Yeah.
WalkingDrunken
03-29-2012 02:38 PM
bakalag
10-22-2009 03:41 PM
capitalistnihilist
07-28-2005 06:59 PM
Quick Reply: tapping sound after 4500RPM
