a tank of 89oct..oops!
Old 12-23-2005, 10:51 AM
ToeKneeC's Avatar
Default a tank of 89oct..oops!
man, i was in such a HURRY that i filled up a whole tank of 89... the ECU will dial back the timing / ignition right?? RIGHT???
Old 12-23-2005, 10:56 AM
BoostLE's Avatar
Just drive the entire tank barely using any throttle and keep it below 4k rpm's as your penence! The ECU can only pull timing back so far, so don't race around.
VAD
VAD's Avatar
Yeah, the ECU will pull timing. Maybe get a bottle of 104 Octane Booster. That could bring up the octane number a little. And it'll clean your injectors, too.
Old 12-23-2005, 11:58 AM
ToeKneeC's Avatar
^ oddly enough, i remember to pour half a bottle of redline SI1 but not to hit '93' instead of '89'.. ijit...
Old 12-23-2005, 12:02 PM
VAD
VAD's Avatar
Tony, what's Redline SI1?
Old 12-23-2005, 12:25 PM
vAnt's Avatar
If you are really paranoid, halfway through the tank fill it up with some 'Premium'.
That way you are driving around on 'Plus'.
Old 12-23-2005, 12:29 PM
Saud2k's Avatar
yeah add some octane booster, that should level it out a bit
Old 12-23-2005, 12:31 PM
Banned
Tugz_S2K's Avatar
[QUOTE=ToeKneeC,Dec 23 2005, 02:51 PM] man, i was in such a HURRY that i filled up a whole tank of 89... the ECU will dial back the timing / ignition right?? RIGHT???
Old 12-23-2005, 12:32 PM
koala's Avatar
Don't add octane booster... just drive the car, and it'll be fine. I probably wouldn't engage VTEC, though.
once you burn off half a tank throw some 93 in there and then you're back at 91.
Old 12-23-2005, 01:05 PM
ToeKneeC's Avatar
Redline SI-1
http://www.redlineoil.com/products_fueladditives.asp
it's like techron.. but better.
i'm not freakin' out... i knew mostly it's gonna be ok... just a doofus thing to do... like ever ALMOST filled diesel into a regular tank?
Quick Reply: a tank of 89oct..oops!
