Suspension torque specs
My tein flex should be here this week, and i am going to install them myself. I have used the search, but i can not find torque specs for the suspension.
What is the factory torque specs for the top two strut bolts front and rear?
What is the torque specs for the lower bolt on the arms?
Thanks alot guys if you know this one
i think i torqued the bolts on top to 35lbs however, that is probably not factory spec. and the bottom one i forgot what it was. you will also need the spec for the upper a-arms for the front.
Originally Posted by Mok,Dec 8 2004, 11:28 PM
hope this helps
suspension torque
top nut 22
pair of 2 top bolts 36
bottom bolt 47
2 A-arm bolts 76
rear stb 32
suspension torque
top nut 22
bottom bolt 47
2 A-arm bolts 76
rear stb 32
Originally Posted by revhi,Dec 8 2004, 11:34 PM
Whats up frank. Modding in the winter, a true enthusiest.
Hopefully come summer ill work on the engine a little more, im still thinking about a turbo kit or SC.
Anyway, if you want to check the teins out let me know. Its going to take me a while to learn how to set them and adjust them right.
