stupid question...but my wheel is stuck after pulling all the lugs off... what gives?
If it's really stuck on there, once you get it off, check to make sure the brake caliper isn't sticking. Look for abnormal pad wear. Heat from a dragging brake would speed the corrosion that makes it stick.
Originally posted by SpeedxRacer
Seems like you could break some studs by having your wheels loose and slamming the breaks. Whats wrong with just giving the top of the whell a slight tap with your palm? I dont see the problem at all and its not like its a 10 hr job to get the wheels off. A slight nudge on the top and it should come right off. If not just give it a kick on the bottom.
[QUOTE]Originally posted by Road Rage
I watched a tire mechanic do it by simply turning his back to the wheel and giving the top of the tire a solid backward kick with his heel. Came right off.
Originally posted by BellevueS2k
jack the wheel a few nothces higher -it'll come right off.
dailodailo
10-18-2003 09:41 AM
