stock s2000 shock dyno
as topic states, does anyone have stock s2000 shock dyno,
i am looking to buy a set of shock, but would like to know the spec on my stock shock before i search for a new set of stock, thank you very much
Originally Posted by Mikes256,Jan 13 2006, 10:38 PM
It's when you get an overweight man to sit in the car, then measure the clearence from the ground. Then you get a hevaier man to sit in the car, remeasure, and so on. This is a highly sophisticated proccess
Originally Posted by xviper,Jan 13 2006, 08:46 PM
I did something like this in my youth. I put the weight of someone (and a sweet young thing she was, too) on the back trunk. Then I added my weight and did a little bouncing up and down to test the springs. I'm not so sure it was very "sophisticated", but it was very satisfying.
Sorry, couldn't resist.
On a side note, if you're still looking for Koni Yellows, seems like they have too soft bump damping compare to stock. That's good for stiff springs but if you're running stock springs and want to keep it that way, I'd suggest something else with more bump damping.
Shock dyno breakdown for those that have never heard of the process...
[QUOTE]
shock dynamometer is a piece of equipment that allows us to diagnose and correct flaws in the damping capabilities of your shock absorber. It works by cycling your shock up and down at a rate determined by the operator. When the
[QUOTE]
