Start Button Not Working
Old 11-24-2011 | 05:41 PM
sakiv's Avatar
Default Start Button Not Working
Ok, so the other day, early in the morning, I went to start my S and as I pushed the start button, I got no response. I sat there trying it for a few minutes and finally it started right up. I don't know if this had anything to do with the fact it was cold (40 deg) ? Or could it be some other issue?
Also, none of my dash controls are working for some reason, its the stock HU.
Anything I need to check for?
Thanks in advance.
Old 11-24-2011 | 06:19 PM
Vanishing Point's Avatar
Bad battery or loose/corroded connection, also check your fuses.
Old 11-24-2011 | 07:30 PM
sakiv's Avatar
Do you know which fuses in particular I should be looking at?
Old 11-25-2011 | 04:53 AM
Check number 24, the main battery fuse. The diagram posted is for a CR, refer to your owners manual for specific fuse info.
https://www.s2ki.com/forums/index.ph...age&img=698616
Miasma
10-25-2017 04:30 PM
F22C S2K
07-30-2015 02:16 AM
JusS2k
07-23-2012 06:34 PM
jonner
07-25-2009 04:05 AM
Quick Reply: Start Button Not Working
